Whats the Best Way to Stop Them Going Glossy
Home Forums Painting in Tabletop Gaming Whats the Best Way to Stop Them Going Glossy
  • #1614513
    panzerkaput
    34066xp
    Don’t you just hate it was to shake the living daylights out of a paint bottle and when you use it the colour is semi to full gloss for some reason?
    I mean I am that sad that I shake, rattle and roll my pots of paint and if I have not used a colour recently I stir it too but sometime they go all glossy or semi glossy. Does anyone know as to why?
    Does anyone know how to stop this happening?
    Does anyone know to correct it once it does happen.
    Thanks
    #1614515
    43722xp
    I never had that problem or I didn’t notice. I had the occasional frosting effect with varnish but that has mostly been gone since I took Mel’s advice on warming up the cans and shake very well.
    #1614523
    necrothrall
    8541xp
    I’ve never had it happen with regular paint before but it does happen quite a bit with certain washes. Druchii violet springs to mind.
    You could try putting a thin layer of matt varnish over the top to bring it back down. I keep a bottle of vallejo airbrush matt varnish handy for just an occasion, I just slap it on with a brush.
    #1614552
    My Vallejo German Grey bottle does that. I guess the medium they used was glossier than for the other paints. A very good shake seems to do the trick though. That’s the only non-Scale 75 paint that I have that needs some special treatment. Everything else is okay – apart from some GW metallics that seem to congeal about a while.
    #1614637
    Many things can make it glossy or give it a satin finish.  Drying too quickly can do that, mixing paint systems by and large they play nicely together, but some don’t play well together i.e. Army painter and tamiya don’t play that nicely together as layer paints in my opinion (tamiya uses isopropyl alcohol as a thinner not water).  Different formulations some of the very bright mecha color range for example from vallejo can do this.  Contrast paints also seen to dry very glossy which makes sense as they work by staining and being translucent, half of them are closer to being inks not paints.
    Did you wash the minis before priming and painting, release agent can do strange things to paint.  Soak in warm water with a bit of washing up liquid, or I use biological washing powder and a bucket and just soak in there for a few hours the rinse under the shower. You could use an ultrasonic cleaner too but the bucket is easier for me as I can just put the whole frame in and be done with it.
    Do you have any agitators in your paints? M5 marine stainless steel nuts I use are good as they don’t clog the dropper of dropper bottles unlike glass beads or bb’s and are corrosion proof so won’t get eaten by the acrylic base.  I ask as some times the pigment will clump at the bottom and what your really painting with is acrylic medium with a hint of tint which dried glossy, conversely if the paint is old you may not have that much medium left in the suspension so it’s either time to replace, or top up with some medium, you can use lahmian medium but if your cheap like me just buy a half litre bottle of artists acrylic matte medium (liquid not gel) for under £10 and have a life time supply and add a drop or two with an agitator and shake like hell.
    For fixing minis once dry your best bet is a matte varnish spray like dull cote, or a good matte acrylic varnish with an airbrush (I use vallejo) this can be a tricky thing to do as humidity greatly effects finish it can go cloudy which is worse than shiny in my opinion, don’t try and quick dry it either just give it a very light misting and leave alone for a few hours, repeat if still shiny, like most things you can easily add more not so easy to remove.
    Finally as a last resort and you feel there is no way to salvage biostrip is a brilliant water based paint stripper no fumes very quick acting yet to find any issues using it on any material (although have heard of resin melting, maybe I’ve just been lucky) which will get your mini back to plastic/metal with a little scrubbing (use a child’s toothbrush won’t hurt any details) and washing. If you have one a water flosser or pressurised spray bottle (pump and spray) work great as mini pressure washers. Again a USonic cleaner can be used if you have one as a final clean before priming.
    #1614641
    One thing i forgot to mention is that arcylic paints are a type of plastic, and are naturally satin in finish, the main difference between artists acrylics and model acrylics is that model acrylics tends to have a matting agent added to their formulation, ive got no proof for this other than anecdotal i.e. some old paint of mine dries to a different finish from how it did when it was new. But i believe that the matting agent deteriorates/reacts over time from contact with oxygen or something reactive in the atmosphere so has less of an effect than it should have, which is probably why adding matt medium fixes the issue.
    One thing i have taken to doing when storing paints for a long while is to get some air tight plastic tubs like these
    and storing the paints in them, i should probably spray them black as well to prevent UV ingress, but as i store them in my loft or a cupboard that minimises the risk from the sun breaking things.
    https://www.amazon.co.uk/Winsor-Newton-Galeria-Acrylic-Medium/dp/B0052YTUCI/ref=sr_1_4?crid=35R1ATS0CQXKQ&dchild=1&keywords=acrylic+matt+medium&qid=1614000074&sprefix=arcylic+matt+med%2Caps%2C155&sr=8-4 thats the matt medium i use, was cheaper when i bought mine a few years ago, but still that would be a life time supply for £15
    #1614653
    17178xp
    I was a massive advocate for Testor’s Dullcote when I first got my Quickshade Strong Tone “dip” – the brown polyurethane varnish from Army Painter, which dries *super glossy*. But now I’m not so sure. When I look back at my old models, they do indeed appear super-matt. But the colours are also a bit “dead” – they’re not so saturated as out of the bottle:
    I painted a few up with edge highlights of the original base colours, and they really popped – but doing that so all my old minis felt like a massive time sink. So I popped a bit of satin varnish over the top. And, while they do have that satin sheen to them, the colours are much more saturated and interesting to look at.
    In short, matt varnish makes colours look dull and lifeless – be careful with it!
    #1614834
    panzerkaput
    34066xp
    Thanks there guys
