What is the Difference between Airbrush Flow Imporver and Thinners?
Home Forums Painting in Tabletop Gaming What is the Difference between Airbrush Flow Imporver and Thinners?
  • #1630596
    panzerkaput
    34066xp
    A question to the Airbrush kings we have on here, what is the difference between Airbrush Flow Improver and Airbrush Thinners and what are their uses?
    #1630612
    killcrazy
    2947xp
    Thinner does what it says, it thins the paint.
    flow improver is an additive that helps to break surface tension, allowing paint to be applied more smoothly.
    if you have a paint that comes out streaky with a brush, or an uneven coat with an airbrush you can resolve it with flow improver. It also acts as a retarder, and also because it breaks surface tension it also acts in small quantities as a lubricant for the paint in an airbrush so it can come out easier, and be cleaned easier.
    #1630708
    43722xp
    A question and a direct, informative answer…. I’m dead and this is wargamers heaven? XD Kudos to @killcrazy
    #1630709
    @killcrazy I think that there might also be a drying additive (isopropyl  alcohol) to the thinner. Luke’s APS did a video on how to make your own and added it to his. It seems to be common in other videos as well. I found that thinner was best for priming to cut the cure time down a little whereas the flow aid was best for regular air work to get the most time to clear out any gunk in the system. Humidity really is a factor to consider when using an airbrush.
    https://m.youtube.com/watch?v=UDmKm3IK0pI
    #1630715
    mischief
    3965xp
    Flow Improver is also supposed to help prevent the paint drying on the needle tip.
