This topic contains 3 replies, has 2 voices, and was last updated by sundancer 2 years, 1 month ago.
Home › Forums › Terrain & Scenery in Tabletop Gaming › Using lasers to recreate the Old West
The design started with a set of elevations I found online for an existing building from the period.
I brought the elevations into Lightburn which is the program that I use for cutting with my laser and has a full package of design tools as well. First I had to scale the plans to fit with 28mm minis which involved scaling the drawing to get it in the ballpark, printing it out, then check the size next to actual minis. When you’re scaling for miniatures using actual scales rarely works like you’d hope.
Once I had the scale where I wanted it I just had to essentially trace the design to get the basic shapes in place. I ended up simplifying the entryway, eliminating the back door and changing it to a window and generally looking for things that didn’t need to exist.
When designing for cutting you need to keep in mind the thickness of the material you’re going to be using because that’s going to come into place if you add tabs to help hold the pieces together. I’m personally in the “fewer tabs are better” camp rather than the camp that likes the corners of all of their buildings look like intricate jigsaw puzzles. Anyway, my main material is 1/8″ birch plywood so that was figured into the design. FYI – for surface details I used 1/16″ birch plywood but the thickness of that material didn’t play into how I was designing things at this stage.
Cutting everything out was really the easy part. I’ve already done a lot of tests with various materials so that I had a sense of the settings I would use to get good cuts and etches. One thing I wasn’t sure about was my roof. I was planning to do the shingles in 1/16″ plywood but that turned out to be way too thick. So that’s why that isn’t done yet. Otherwise, I only had one failed attempt due to material that was warped more than I had initially thought. Otherwise, it was a smooth process.
Gluing on all of the surface details was where the thing really started looking good. This is also where I got to see things that I will probably change in the design to simplify it yet again. Areas that didn’t need to be as complex as they were and a couple of things I forgot to add – which I can still add now.
Painting was also pretty straightforward. I used the laser again to create a stencil for the General Merchandise sign on the front and airbrushed that on. I had considered adding an actual sign to the front rather than painting the front of the building. The period buildings did it both ways – but I opted for paint on the walls. It’s turning out cleaner than I thought I wanted initially but I’m leaning towards the idea that this is a newer store from a wealthy businessperson so it’s going to stand out from the rest
The inside looks so nice I’d like to fill it out with shop goods but I don’t know if I’m going to be that ambitious.
This looks quite interesting. Any particular reason why you chose a forum entry over starting a project in the Project System?
I guess it’s because I know what a forum is but I don’t know what a “project system” is. If I’ve made some sort of faux pas by posting this here I suppose I can delete it.
Warcradle Tease More For Next Armoured Clash Releases!
Sanguine Sin Stalks The Streets Of Venice In Carnevale
Spectre Miniatures Launch New Mythos Supplement This Week
Delve Deeper Into Warhammer Underworlds With New Warbands
Pre-Order New Slaves To Darkness For Warhammer Age Of Sigmar
Pre-Order New Edition Urban War Gamebox From Seb Games
Callisto Rides & Roars Into Bad Roll Games’ Punkapocalyptic
Wargames Atlantic’s New Plastic Peasants Are Revoltingly Good!
Separatist Call On Clanking New Droids For Star Wars: Legion
Snatch Up Corpses With Warmachines’ New Necrohavester
Fight Alongside DakkaDakka’s New Stormpride Sisters On Kickstarter
PWork Wargames Running Big New Black Friday Sale!
Loads More Burrows & Badgers Previews For New Starter Set!
Warlord Offer Sneak Peek Inside Bolt Action Armies Of Germany
They Have A Snow Troll! New Middle-earth SBG Miniature Reveals
Dive Into Bolt Actions’ 28mm Winter US Army & Airborne Collection
Slithering Creatures & Tech Savants Join Necromunda Range
FREAKZ! Mutant Murder Machines Available From Osprey Games
Cover Your Bases In Dead Animal Bits From Wargames Atlantic
New Ottomans & The French In Egypt From Perry Miniatures
Build Your Crusader-era Islamic Army With Victrix Miniatures
A New Crew Comes To Freebooter’s Fate & A Pirate Squirrel!
Buckle Some Swashes With Two New Black Scorpion Miniatures
Recruit New 15mm Desert Infantry From Slave 2 Gaming
Battle Through New Micro Art’s Pre-Coloured Japanese Terrain
Grab Digital Armoured Clash Rules From Warcradle Studios
Steamforged’s Epic Encounters Hit The Ruins Of Symbaroum!
The Fidwogs Marching Out Soon For ZombieSmith’s This Quar’s War
Crooked Dice Gives New Home To Sinbad Range For 7TV Fantasy
Spectre Miniatures Reveal Limited Remembrance Diorama
COG – Trading Bazaar
