Sharp Practice Bases – Where to Get or How to Make?
Home Forums Historical Tabletop Game Discussions Sharp Practice Bases – Where to Get or How to Make?
This topic contains 5 replies, has 3 voices, and was last updated by  avernos 6 years, 1 month ago.
  • #1307126
    lupa15
    11253xp
    Greetings!  I am starting my endeavor into the world of Sharp Practice.  One of the things that I noticed is the wonderful round bases that can be slotted into rectangular holders as can be seen in this picture:
    SharpsPracticeBases
    Is there a good place where one can purchase a variety of these bases (even if some assembly is required).
    Or failing that is there a good way of making these bases without a power saw and sander?  I have seen some 1/4″ sheet MDF but my understanding is that you need a decent power saw to effectively cut the pieces before finishing with sander.
    Thanks in advance!
    #1307130
    Warbases in the UK sell them
    They make to fit either 1p or 2p coins. They also do them for metric size holes as well
    https://warbases.co.uk/?product_cat=movement-trays
    #1307133
    33984xp
    warbases as @torros said, or http://www.sarissa-precision.com/collections/conversion-trays
    both companies are excellent and will tailor what you need if you email them, 2p trays are great as the bases have a nice heft ^^
    #1307180
    lupa15
    11253xp
    @torros @avernos Thank you! They both have quite the selection to choose from!
    #1308309
    lupa15
    11253xp
    @torros @avernos  I have decided to go for Warbases UK as I found their website and options selection pretty straightfoward.  Any recommendations for the size for rectangular calvary bases?
    #1308310
    33984xp
    something close to 25mm x 50mm is generally the accepted for 28mm cavalry and they’ll fit without being crushed. I do like the pill shaped bases.
    If you are basing to a certain size 20 x 40 will be tightish but will fit a 50mm square foot print which I know some games use
