This topic contains 13 replies, has 10 voices, and was last updated by sundancer 1 year, 10 months ago.
Home › Forums › 3D Printing for Tabletop Gaming › Question about removing gradient lines
Ok I will admit I don’t have a 3d printer, but have recently purchased some 3d models from shapeways… They have clearly visible lines and gradients. My question is how does one remove these easily without spending a decade sanding?
Friends have used acetone to soften the plastic and soften/diminish the gradient lines in print jobs that they have done.
* It only works on certain plastics.
* Putting it in an enclosure (fish tank, sealed acrylic box) and letting the fumes work overnight gives a more subtle effect. Warming the acetone makes the fumes stronger and more aggressive.
* Rubbing the acetone directly on the piece acts similar to sanding it.
**** I have no actual experience with this, it’s just what I’ve been told by friends explaining how they do it.*****
Hi,
The acetone smoothing is often used for ABS, so if you printed PLA it will not help. Then sanding and/or priming with a filler-containing primer might help you.
ABS PLA how can I tell?
Not so easy to know visually what it is… perhaps you can cut of a small piece (from the base, perhaps the underside of it) and put it in some acetone. If it melts you know you can use acetone for smoothing.
Also, I have never smoothened anything myself, but I have read that you have to be very careful not to overdo it, as you loose details in the process.
well the models are Aircraft fortunately there is not a huge amount of detail to loose and I will add that in afterwards 🙂
If it’s from Shapeways it is either Acrylic (Fine Detail) or Nylon (Strong & Flexible). I’m not sure if either of those is affected by acetone. Your best bet is simply take some 300+ grit sandpaper and gently hit the areas that are most noticeable.
Another option, I would experiment before using a printed piece, would be to get some Auto Filler Primer spray paint. Shoot the filler primer then lightly sand. The filler primer should fill, at least partially, the layer lines on the print.
Not that it will help you on this occasion, but I found printing with the “frosted extreme detail” material was very good for minimising the visibility of these kinds of lines on Shapeways prints.
I find that printlines are not really noticable when painted unless viewed up close. For tabetop purposes printlines can usually simply be ignored.
I also find that I have to avoid painting techniques like wash or drybrushing, as those techiques serve to highlight the lines.
Yes I was having this discussion the other day with a friend, going to have to avoid the use of washes and dips unless I get the entire model sanded down well.
I have yet to try these but they are on my to do list for PLA.
Clear Nail polish or a polyurethane clear coat. *Should* remove a good number of the layer lines. However may show brush strokes if its applied to thick or allowed to dry to quickly while brushing on. Oh yes, count on runs if you use polyurethane.
Another option is to use Primer that is a filler. Something like this. Then wet/dry sand with a sanding sponge and then paint. It is work but I have seen the results on the 3D subreddit forums and you can get some nice results.
We can explore our knowledge to read your blog.
The Emperor’s Children Show Off With New Warhammer 40K Preview
Brand New Painting Competition Coming To UK Games Expo 2025
Games Workshop Set Out The Road Maps For Warhammer In 2025
The High Elves Bring Glory To Warhammer: The Old World
The Soulblight Gravelords Rise With New Minis For Age Of Sigmar
New Quests Await For Corvus Belli’s Warcrow Adventures
Delve Deeper Into Dungeon Saga With New Expansion Sets
The Inhumans Boost Their Ranks In Marvel: Crisis Protocol
Ranged Reinforcements Lock & Load For Corvus Belli’s Warcrow
New Bolt Action Compendium Coming Soon For 3rd Edition
Blood On The Sands Kickstarter Date + Wargames Atlantic Collab!
American Civil War Horse Teams Pop Up On 1st Corps Webstore
New Expansion Packs & Essentials Sets For Infinity In February!
Famous Pirates & Injured Gunslingers By Black Scorpion
Borgit’s Beastgrabbaz Join The Scraps Of Warhammer Underworlds
Pre-Order The Yoroni! New Conquest Faction From Para Bellum
Lay Down Fire With Wargames Atlantic’s WWI Machine Guns
Pre-Order The Army Painter’s New John Blanche Paint Sets
Lucid Eye Release New Elf Warriors & Samnite Spearmen
Renegade Taking Pre-Orders For New Axis & Allies Games
New Terrain For Gale Force Nine & Thunderhead’s HexTech Range!
15mm Hornblower Shieldmaiden Cavalry Available From North Star
Steamforged Games’ Maelstrom Whips Up A Storm In Warmachine
Pick Up Vagrantsong Miniatures From Wyrd Games This Month
Medbury Miniatures Ride Out With New Scottish Hobelars
Looking Ahead To Cosmic Antics In Marvel: Crisis Protocol
Andy Hobday Joins Wargames Atlantic As Creative Director
A Bretonnian Wyrm Slayer Comes To Warhammer: The Old World
Black Site Bringing Don’t Look Back Core Box To Gamefound
Perry Miniatures Working On 28mm 1793 Vendeans Royalists
Pulp, Punk, Horror & Weird Tabletop Game Discussions
