This topic contains 6 replies, has 6 voices, and was last updated by mage 5 years, 8 months ago.
Home › Forums › Painting in Tabletop Gaming › Prop Documents: Making handouts look aged
Im doing some propers for Call of Cthulhu, Chaosium’s Iconic RPG. Im printing out some handouts but want them to look the part. Anyone know how to make a sheet of white paper or white paper handout look aged? Sort of sepia-like?
I’ve googled it and there is advice out there but comments on said sites kind of contradicting or listing out the bad points.
Would be great to talk to people on here and see what fellow Beasts have done first hand.
The coffe or tea trick works best for me. Just put paper on cookie sheet and pour a weak coffee or strong tea mix on and turn oven to 180 or 200. Check it in a bit . cant remeber how long . If u leave in two long looks great but will be fragile . lemon juice also works . Paint page with lemon juice and let dry . crumpling beforehand gives it an even more decrepit look . havent done this in a while . but do a practice run b4 using ur real prop
I normally scrunch up the paper into a ball, unfold it, then tear small bits of, usually around the corners to make it look ragged. Make a cup of tea, then wipe the teabag all over the paper, letting the tea coloured water soak in. Let dry. Perfect aged-looking document.
From helping nieces and nephews do English and History homeworks… Print or write what you want on it first. Decent thick paper, give it a quick scrunch up and stain with teabags, but try not to get it too wet and let it dry slowly. You can also burn and singe the edges with a lighter or matches or tear them as said above. Thin paper is more likely to disintegrate after it drys, especially if you try and roll it into a scroll etc.
If you want to put a wax seals on it, melt candle wax and press something suitable into it.
Do this a lot for various am dram things and just for fun:
crumple the paper into loose balls then flatten out
tear corners, if you smoke or know a smoker, nick a cig off them and use to burn a few select holes in paper
fill a jug with boiling water, add a tea bag and some lemon juice, leave to cool down, then soak a sponge in the mixture and wipe over the paper (be warned if you have printed with an injet printer the ink may run as most are water soluble), repeat to get the aged look you want. it will dry lighter, but you can control the aging by repeat sponging,
then leave to dry, no need for an oven just a warm place or sunlight will do
Well I know what I am doing this weekend. Now, all I need is an excuse to give my players a scroll now.
Westfalia Creating Stunning Red Brigade Minis For Trench Crusade
Unarmoured Visigoth’s Join 1898 Miniaturas’ Historical Range
Hobday & Hicks Preview Fantasy Supplement Rulebook, Warhost
Avatars Of War’s 28mm Plastic Marauders Back On Sale!
Firelock’s New Characters For Your Blood & Plunder Crews
Empire Of Man Range Expands For Warhammer: The Old World
Deep-Cut & The Army Painter Team Up On Speedpaint Pens?
Grab New Spectre Mythos Core Box & More For Lovecraft Adventures
Bad Squiddo Bring Pulp Heroines To Kickstarter This Week!
Victrix Preview Late War Germans For 28mm World War II Wargames
18
Brand New Death Korps Minis Mobilise For Warhammer 40,000
Orruk Warclans Get New Battletome For Warhammer Age Of Sigmar
The Gitmob Ridez Again In Warhammer Age Of Sigmar!
Aeldari Phoenix Lords Return To Warhammer 40,000!
Middle-earth: War Of The Rohirrim Pre-Orders This Weekend
Warcradle Tease More For Next Armoured Clash Releases!
Sanguine Sin Stalks The Streets Of Venice In Carnevale
Spectre Miniatures Launch New Mythos Supplement This Week
Delve Deeper Into Warhammer Underworlds With New Warbands
Pre-Order New Slaves To Darkness For Warhammer Age Of Sigmar
Pre-Order New Edition Urban War Gamebox From Seb Games
Callisto Rides & Roars Into Bad Roll Games’ Punkapocalyptic
Wargames Atlantic’s New Plastic Peasants Are Revoltingly Good!
Separatist Call On Clanking New Droids For Star Wars: Legion
Snatch Up Corpses With Warmachines’ New Necrohavester
Fight Alongside DakkaDakka’s New Stormpride Sisters On Kickstarter
PWork Wargames Running Big New Black Friday Sale!
Loads More Burrows & Badgers Previews For New Starter Set!
Warlord Offer Sneak Peek Inside Bolt Action Armies Of Germany
They Have A Snow Troll! New Middle-earth SBG Miniature Reveals
Pulp, Punk, Horror & Weird Tabletop Game Discussions
