Project: more then 3 images
Home Forums Technical Support Project: more then 3 images
This topic contains 5 replies, has 4 voices, and was last updated by  waxer 6 years, 5 months ago.
  • #1213991
    waxer
    705xp
    Every time I put more than 2-3 images in project entry, after publishing it, it just disappears. It’s a little tedious to write it again and again. Is it possible to fix this?
    #1214162
    tuffyears
    23171xp
    i had this problem, just post fewer images
    #1214200
    waxer
    705xp
    Fewer is 1 or 2. Maybe glitch could be fixed.
    #1214211
    18060xp
    Or resize them.  I have started resizing my images prior to uploading and, excepting that the site has been frequently running slow, haven’t experienced any issues uploading images.
    #1214406
    davehawes
    7768xp
    I’ve had this problem a few times. It would be nice if it just warned you the post was going to fail and let you keep the text and other bits. Losing a whole post after working on it for 30 minutes isn’t ideal. You can eventually post the images by editing the post several times. I am sure making the images smaller would help as well, but sometimes it’s nice to post big images 🙂
    But yes, the best solution I have found for now is to add a few images at a time and keep re-editing the post.
    #1214454
    waxer
    705xp
    I’ll try with re-editing post, good idea.
