Home › Forums › Painting in Tabletop Gaming › Paint Brushes – Help and Advice
- This topic has 26 replies, 15 voices, and was last updated 5 years, 5 months ago by
Clun1995.
June 13, 2020 at 3:39 pm #1538431
Plea for help chaps. Got diagnosed with rheumatoid arthritis last year that has affected my hands.
To ease the pressure of gripping brushes I have had to use kitchen towel and masking tape to increase the diameter of the handles.
While not elegant has helped however as you can imagine needs to be refreshed regularly as they wet.
I know that you can get attachments for pens and pencils to help with the grip, but wondering if anyone has come across anything that would work for brushes?
Cheers
Byan
June 13, 2020 at 3:52 pm #1538451I’ve not seen anything, Army Painter brushes have a large triangular handle that one of the pen soft grips may actually fit around.
I’ve asked about and I’ll see if anyone else has any thoughts to feed back
June 13, 2020 at 3:53 pm #1538457Have a look for a thing called Plastazote Tubing – I know people who have used it for pens to help grip them. It might be useful as you can get it with very small holes in the middle, which would be a suitable size for brushes. Plus you can cut it to fit.
June 13, 2020 at 3:54 pm #1538458June 13, 2020 at 4:08 pm #1538465Couldn’t you use some plastic putty for that or would that make the brush to heavy?
June 13, 2020 at 4:08 pm #1538466June 13, 2020 at 4:28 pm #1538478What about making some grips from sugru? It’d be perfect for that. The immediately obvious idea is to mould it over the paintbrush then when it needs replacing, slide the sugru off the brush and pop it onto a new one.
Thermoplastic (those little pellets you drop into hot water) would also do, but the finish would be quite hard – sugru retains a slight rubbery springiness. Then again, something like “blue stuff” or Oyumaru would give the benefits of both – heat to make pliable, wrap it around the brush and when done, simply cut it off, pop it into a pan of hot water and re-use on your next brush (if you’re careful you could even put finger indents into it while it’s setting on the brush if you want to be truly “egonomic”)
June 13, 2020 at 4:30 pm #1538484
green stuff a substructure perhaps?or switch to black nasty or gaffa tape (duct tape etc)
A friend with arthritis and couple old war wounds can’t grip a pen with his thumb and finger but he can write with the pen between the first 2 fingers?
June 13, 2020 at 4:41 pm #1538489weirdly Oyumaru is what I thought of, just done a quick video. I think it would be ideal, and it’s reusable.
June 13, 2020 at 4:45 pm #1538490https://www.youtube.com/watch?v=EIzQCafHf94
This is where I bought mine, half the price of amazon or the miniature modelling version
http://www.metalclay.co.uk/oyumaru-instant-mold-moulding-compound/
Hope you find something that works out for you
June 13, 2020 at 5:49 pm #1538505Some of my students have special needs and the kids come in all sizes. One of the teachers uses Silly Putty because it is firmer than clay, molds to the hand easily, and (very important to her!) is very easy to wash and reuse. Check out school supply stores for similar products, again the Special Needs section has amazing tools for adapting almost anything.
Soft foam cylinders that one can push a hole into with a pencil or dowel for the brush handle to slide through have also made appearances in my room as many kids come with their own modified tools and materials.
I just have the common form of arthritis but have found holding the brush between my pointer and middle finger very helpful.
June 13, 2020 at 10:26 pm #1538536you should check out these brushes to see if they are a help @SirHumphreyRtd
Royal & Langnickel SG-303 5 Piece Round Set- White
June 14, 2020 at 12:43 pm #1538723June 14, 2020 at 9:56 pm #1538877I did some google research and what is out there is expensive. I have not used it but I think Sugru would work well. Also was going to suggest craft foam and or surgical gause \ tape. Or if you found some pens with silicone grips you may be able to remove them and attach to the brush handle. I also found a video of a painter using aluminium foil and electrical tape. Granted he’s not painting miniatures but it may be worth a look: https://youtu.be/dtObPn6_yis
June 15, 2020 at 10:08 pm #1539418 -
![31MV5ScxSAL._SL500_AC_SS350_[1]](https://images.beastsofwar.com/forumuploads/1539418/2020/06/15/wlymhp21kyxymedqrm6fxnhxypzulr78.jpg)
