Image Rotation in a Project
Home Forums Technical Support Image Rotation in a Project
This topic contains 5 replies, has 4 voices, and was last updated by  civilcourage 6 years, 5 months ago.
  • #1242944
    marktarver
    3667xp
    On the older 1.0 I used to have to edit the HTML code to do a rotateimg=90 due to taking pictues using an iOS phone and it hardcoding the rotation into the picture.
    I have tried to create my first project, and it is very slick and easy to add content. However I have the old problem in that my pictures need to be rotated, but I cannot see a way of having the option in the project to do this, or how to edit the html myself to fix it?
    Is there a way to rotate images once uploaded into the projects please?
    Cheers, Mark.
    #1265354
    civilcourage
    11134xp
    @marktarver i’m having the same problem, even if i rotate the original image i get a rotation problem, i now have some pics upside down!
    @warzan are there technical wizards your end who could help with this?
    Here is an example: https://www.beastsofwar.com/project-entry/1261293/
    Can we rotate the picure in the project somehow?
    #1265387
    43167xp
    Wordpress itself supports rotating but only in the backend. I can’t find any command to “force” WP to do so in the frontend.
    #1265592
    lloyd
    17986xp
    Hi @marktarver @civilcourage @sundancer
    Image rotation is on a list of features we have in mind but I have no info whatever we can create a feature that will work or when that might be yet.
    In the meantime, there are free online image rotators that may help. Try searching “online image rotation tool” on google.
    #1265605
    43167xp
    Basically this shouldn’t be needed since every OS (mobile and stationary) comes with a rudimentary function to edit pictures today 😉 So just rotate it before upload and all is well. (yes, I know, some mobile phones are a PITA in that regard, I’m just playing devils advocate here)
    #1265811
    civilcourage
    11134xp
    @lloyd & @sundancer thanks for the responses. I had a go at rotating the picture on my phone and re-uploading but it still came out wrong. Ill just try some more and see what happens.
    Update – Rotating the picture didnt work but cropping it on my mobile a little seemed to work (even though the picture is in exactly the same orientation!)
