Image Previews in Project Galleries
Home Forums Technical Support Image Previews in Project Galleries
This topic contains 4 replies, has 3 voices, and was last updated by  onlyonepinman 6 years, 7 months ago.
  • #1212108
    18072xp
    Something a bit weird seems to be happening with my image thumbnails in my Image Galleries.  It’s generating thumbnails of different images.
    One of these things is not like the other…
    Screenshot_20180618-135457
    #1212110
    18072xp
    It might be slightly more serious.  On one of my older project entries the actual image itself is also incorrect.  I have tried deleting the image and re-uploading it but it’s the same every time.  I suspect that this may be a file naming issue.  The file is called “11.jpg” when uploaded so it’s entirely possible that if images are being placed in a central repository and a file with that name exists I am actually seeing someone else’s file rather than my own.
    #1212326
    lloyd
    17986xp
    Hi @onlyonepinman
    Thanks for the info, this is something we are looking into. In the meantime, you may be right about giving your images more unique names.
    Cheers
    Lloyd.
    #1212327
    ntrabbit
    834xp
    Rather than just galleries, I seem to have lost the profile images and banners for a good chunk of the people on the site, including my own. Just shows the failed image load in comments and on profile pages, and completely blank here on the forums.
    #1212567
    18072xp
    @lloyd it’s not always possible if you’re using a mobile.  I can’t easily rename image files via my mobile.  Also, it’s not possible to predict what a unique filename might be.
