HobbyZone work space organisers.
Home Forums Painting in Tabletop Gaming HobbyZone work space organisers.
This topic contains 19 replies, has 6 voices, and was last updated by  totsuzenheni 4 years, 2 months ago.
Viewing 15 posts - 1 through 15 (of 20 total)
  • #1565375
    totsuzenheni
    5651xp
    Has anyone used HobbyZone work space organisers? Are they good? What are the pros and cons?
    Does anyone recommend or advise against any specific modules?
    What tools have people used to remove the interconnecting stubs?
    Are there any good alternatives to HobbyZone’s organiser products?
    #1565376
    totsuzenheni
    5651xp
    For reference, here is a link to the HobbyZone website, and here is a link to the Reorganize my hobby space with HobbyZone OTT project by @frederique555.
    #1565409
    redben
    9415xp
    I’ve got a few of their paint racks. I’ll upload a photo below. I don’t have a full modular all the bells and whistles set up. They came with magnets you can slide into holes on either side of the paint rack if you want to connect them together.
    #1565412
    redben
    9415xp
    0FA363B8-DC47-4C03-924B-790B58334335
    #1565450
    jjgrubb
    2726xp
    One of the other members of my podcast has a hobbyzone setup which he absolutely loves, he’s going to get a quick vid done for you tonight which I will share for you later (likely my morning) just showing it off and giving his opinion. Hope it helps.
    #1565457
    totsuzenheni
    5651xp
    Please pass on my appreciation to your podcast member @jjgrubb.
    #1565488
    tobymagill
    1414xp
    I have (more than) a few – improving my hobby area has been what has kept me sane during lock down (pics of modules/set up below)
    In terms of tools needed, I used a Stanly knife to trim the connectors, wood glue to join the pieces and masking tape to keep things together while the glue dried. I also used a a rubber mallet to knock the magnets into the holes (no glue needed), but any hammer/blunt object would do. One tip I found useful was to mark the polarity on the magnets with a felt tip pen before I started so that I put them in correctly.
    The most useful modules I have found are the paint racks, six draw units (for bits), a 3 draw unit (for tools), the spru holders and the display cases. The sprue holders and display cases were the biggest supprise, but I have found I really like being able to see my minis while I build/paint and that keeping the spurs out of my build area has made things a lot easier.
    Hope this helps – let me know if you have any questions and I will do my best to answer them.
    TobyIMG_3110IMG_3111
    #1565492
    totsuzenheni
    5651xp
    Has anyone tried out the Paint Hangers and Paint Hanger Base, without attaching them to a wall?
    #1565516
    radegast6
    5662xp
    I have a lot of their stuff and its amazing, highly recommend. very robust.
    #1565523
    flatbattery
    8265xp
    DSC_0105
    It’s fantastic stuff, can’t say anything against these that I’ve got. The only advice I can give is make sure your magnets are all aligned the same in each module and clean up excess glue as it can make the drawers tough to open.
    #1565526
    totsuzenheni
    5651xp
    I see you have the OM07b – Brushes and Tools Module there @flatbattery. How do you find it? Do you think that you would have preferred the OM07a – Brushes and Tools Module now that you’ve used the OM07b?
    #1565528
    flatbattery
    8265xp
    @totsuzenheni to be honest I find a bit fiddly to use, where it is now (close and to the side) is the easiest place for access but still not ideal. In hindsight I would have gone for the OM07a, if I didn’t want to keep the tops clear for paint and handle storage.
    #1565529
    tobymagill
    1414xp
    @totsuzemheni – if it helps i spent a long time weighing up between those two modules. I went with 07b in the end as i didn’t want to sacrifice space for paint racks on the top row. 7b has worked our great for me. The only benefit i can see of the 7a now is that the tool rail is probably easier to remove and replace if you want to use it for hanging masking tape etc.
    #1565538
    totsuzenheni
    5651xp
    I see it on your rig now @tobymagill . The painting racks are a consideration for me too of course, and at the same time on the one hand i think i like the looks of the paint brush holder part of OM07b because one paint brush won’t get hidden behind another, and on the other hand i think i would prefer the tools holder on OM07a. Thinking about it i think i would like a merry-go-round paint brush holder version of OM07a.
    #1565854
    jjgrubb
    2726xp
    As promised. Sorry for the verticle film it was done on Georges phone
