First Print (Warning: Unspectacular)
Home Forums 3D Printing for Tabletop Gaming First Print (Warning: Unspectacular)
This topic contains 20 replies, has 4 voices, and was last updated by  wesadie1969 5 years, 7 months ago.
Viewing 15 posts - 1 through 15 (of 21 total)
  • #1392077
    wesadie1969
    2729xp
    Well I bought the Prusa I3 MK3 in the end. All built and calibrated and seems to be working well.JP
    Now to start looking for bigger challenges.
    #1392246
    ianska
    704xp
    Looks like it’s set up nice 🙂
    What sort of challenge are you looking for?
    #1392292
    wesadie1969
    2729xp
    Made some base insert templates for Wild West Exodus to get sizes right and they have printed very well and  I’ve just set the first part of Printable Scenery’s Small Winterdale Cottage going (4 walls), it just under a 12 hour print.
    Is 3D printing always this nerve wracking?
    #1392320
    ianska
    704xp
    It is at first, then you get used to it and you’ll be running prints overnight dreaming spaghetti plastic dreams. I still find I wake up at random times in the night and the first thing I’m thinking is “I wonder if the prints are fine” and have to head off to the print room to check on everything lol
    12 hours is a good time to keep the prints to though. Means if things mess up you don’t lose too much 🙂
    #1392334
    wesadie1969
    2729xp
    5 hours in of 12.
    WCottage
    #1392336
    31125xp
    looking great mate
    here are some of the castle bits were printing for Normandy
    15582678696528432236914732092919
    now the interesting thing is two of these towers have been put together from completely failed prints (just with a bit of out of the box thinking and some super glue lol)
    15582679571178851676812629339863
    15582679892248012055799795662195
    15582680182751420552817350350709
    All three beds are working away and so far so good!
    #1392347
    wesadie1969
    2729xp
    I guess the beauty of failed terrain prints is they can still be utilised as ruins etc.
    That’s quite a production line you have going there Warren.
    #1392503
    ianska
    704xp
    Printers breed lol
    IMG_5905IMG_5904
    #1392538
    wesadie1969
    2729xp
    Disaster. 97% complete and the print came loose from the bed. I think I should have used a brim.
    Not a complete loss as the print is only missing a tidy layer and the 4 pegs for the roof which can easily be replaced with magnets.
    disaster
    #1392539
    ianska
    704xp
    I’ve just printed that too. Nice building and can;t wait for the rest. I did the roof a 0.12mm layer height and it came out super smooth,
    #1392554
    wesadie1969
    2729xp
    I’m printing at .15 layer height at the mo.
    Did you use a brim for the main building?
    If this one fails, I’m going at the bed with acetone then a glue stick, it’s a great learning experience this 3D printing lark.
    #1392555
    ianska
    704xp
    No brim. I only use a brim with small pieces that are likely to fall off. It seems odd that it came unstuck that far into the print with that much of a surface area on the bed. Are you sure the beds level? not sure how it works on the Prusa. Do they have auto leveling?
    Coming unstuck can be a combination of things though, bed leveling, type of PLA used or a sudden change in room temp where the bed cools too much and the print unsticks before it’s got up to temp again. I’d try the acetone and a level before hairspray and glue though 🙂
    #1392611
    wesadie1969
    2729xp
    Hmm, it was late at night and I had the room window open, so maybe the temp dropped too quickly for the bed to compensate.
    #1392653
    ianska
    704xp
    I’d say that was it. It’s getting cold here now and I’m finding I have to shut the print room window overnight. as long as the room stays under 32 degrees it’s normally all good
    #1392740
    shingen
    13941xp
    Hi wesadie1969,
    Good choice of printer 😉 Congrats.
    Looking at your first print (a whistle) I think you may want to tinker a bit with fine tuning Z axis, it may be only a picture but I think your hotend maybe too high over printbed at first layer. That doesn’t look like that on your next print, but whistle’s bottom looks uneven.
    I use older type of printbed surface, but found out the hard way that one should always use some glue stick, even when printing simple PLA.
