Home › Forums › 3D Printing for Tabletop Gaming › ELEGOO Mars printer
Tagged: 3D-printing, Alternative Guard Models, Astra Militaurm, Female Guard, IG, Imperial Guard, Kill Team, Necromunda, Warhammer, wh40k
This topic contains 18 replies, has 14 voices, and was last updated by nyckeau 5 years, 4 months ago.
August 26, 2019 at 11:04 pm #1429862
So now I have an SLA type printer just making a few vehicles for my chain of command wargames.
August 27, 2019 at 5:23 am #1429870The prints look very good. How long did they take and how bad is the smell? From what I heard resin printers are a bit smelly
August 27, 2019 at 3:54 pm #1430060The jeep and Paz 38t body took about 3 1/2 hrs each. The sexton about 5 hrs. All printed at .05 which had I done the jeep on my press it would have taken 12 hrs. It’s like super fine. But for resin printing it’s like draft. The smell is quite bad but it’s in the shed so with the door open it’s not too bad. Wouldn’t want it in the house. However I read some resins smell worse than others. I’ve ordered a different brand to see if I can tell the difference.
August 27, 2019 at 7:01 pm #1430121I have used Elegoo’s own resin and I don’t think the smell is bad! the IPA to clean up is much more smelly. I have only had my printer for about 4 weeks and only printet about 20 items. But I must say I love it. Now I just have to learn hav to 3d model 🙂
August 29, 2019 at 6:37 pm #1430689August 29, 2019 at 8:32 pm #1430704I think keeping a window open is a good idea either way …
Great detail, but the speed (or rather lack thereof) is not there yet IMHO.
August 30, 2019 at 5:15 am #1430711I have my Elegoo Mars for about a month, using just Elegoo Gray Resin it doesn´t smell at all.
Printed a lot so far.
I Love this printer ^^
August 30, 2019 at 5:16 am #1430712August 31, 2019 at 9:52 am #1431038they look great. I’m just about to print a Pz4. I’ve found a few times I have failed prints where it is stuck to the FEP, but I’ve just re-leveled my bed this morning. So I hope this cures the issue.
October 28, 2019 at 1:43 pm #1451128And yet another happy Elegoo Mars user. Got my last week and I’m amazed by the detail it can produce. Some samples bellow:
July 27, 2020 at 7:51 am #1553523July 27, 2020 at 9:17 am #1553582Hi – quick question for the resin printing experts. Do you think they are safe to use if the only hobby space avaliable is a loft with no windows?
I have been looking at resin printers but have assumed that due to the lack of windows where I hobby they wern’t an option. If it helps the loft is pretty big and runs the length of a normal sized UK house. I was hoping that with less smelly resin and water washable options, there might be some combination I could get to work.
Cheers in advance for the help – the printed minis look awesome by the way.
September 19, 2020 at 11:14 am #1567852Recently got an elegoo mars pro and it’s changed my hobby life! Had a cheap filament printer too and it’s good but more for large terrain pieces etc
September 24, 2020 at 10:37 pm #1569266I recently bought the Elegoo Mars Pro and am using “PrimaCreator Value Water Washable Resin”. After a couple of misfires due to the ogre-sized minis falling/getting sucked off the premade supports, I have started doing my own supports and yes, the machine prints very well. I still need to learn and do tweaks, but from my third print they have all been good.
The water washable resin I have is very low smell and should not be much of an issue even in windowless lofts or wherever. I would probably want to air out every so often just in case.
September 25, 2020 at 2:12 am #1569278I have had an elegoo Mars for about 5 months now. I have never ceased to be amazed with the quality of the prints. I have printing minis in every scale from 10mm to 28mm including some 40k dreadnought sized pieces with very few issues and most of those problems came from trusting presupposed files from thingiverse. As for the smell, I have my printer in a basement with very little ventilation and like a few others have said the alcohol smells much worse then the resin. In the last few months I have switched over to the Elegoo water washable resin which has very little smell at all, and removes the need for alcohol. I would highly recommend making the purchase if you are on the fence…as long as you have the will power to resist subscribing to every patreon that offers stl files.
Those guardsmen up above are feudal guard by “the makers cult” on their CGTrader store the files for the squad are about $10 if I am not mistaken. They have units on there to build an entire army even vehicles
