Are die-cutting and embossing machines any usefull?
Home Forums Terrain & Scenery in Tabletop Gaming Are die-cutting and embossing machines any usefull?
This topic contains 7 replies, has 6 voices, and was last updated by  shingen 5 years, 1 month ago.
  • #1463191
    43063xp
    So my wife got herself a cheap die-cutting and embossing machine to start making cards. She had used it for some time but now the thing happened everybody said would happen with the cheap ones: it doesn’t cut anymore. The bearings are having to much play and you can only do embossing with it. So she got herself a new one, this time a proper one. (This one.)
    Now I have the old machine and I’m trying to think of a way on how to use that thing for our hobby.
    Do you guys have any ideas?
    #1463192
    damon
    7527xp
    Making tops for bases or floor/wall patterns for terrain?
    Is there a tool for corrugated card to make corrugated sheets for terrain?
    #1463195
    Theres a little handheld machine you can get from railway modelling suppliers to make corrugated sheets. Saw it for the first time a couple of weeks back. Thought it was great
    #1463200
    43063xp
    @torros for that (corrugated sheets) I have the “Corrugator Tool” from GSW en route via the OTT SW packet 😉
    What I would need would be some kind of stencil to press into foam or other materials… like the textured rolling pins but in a flat version
    #1463226
    Anonymous
    0xp
    I’m pretty sure I watched my dad use thick foil with corrugated cardboard as a “mould” to make sheets of  corrugated iron  for something on the train set.  It wouldn’t survive wargaming though.
    Can you take the machine apart and use it for terrain?
    #1463228
    7027xp
    Well “if” you can get square or circular dies, one thought I’ve had in the back of my mind would be to scan a gaming mat and then print out a colour sheet with the texture on. The use a die cutter (mainly you’d need this for circular bases as square ones can be hand cut with a scalpel) to cut and then glue onto a laser cut MDF base (for example a 1″ or 25mm circular base). Thus your minis now have bases that perfectly match the gaming mat, and it’s quick to do (other than the need to drill and pin the mini to the MDF base, but if you get a production line going……)
    #1463267
    43063xp
    @robert I had it apart to see if the bearings could be fixed (they can’t) and it’s nothing really nearly good looking. Just a heavy frame with two heavy rolling pins.
    @phaidknott I think circular dies would be doable but… the machine doesn’t apply enough pressure any more to cut…. that’s the whole reason why it ended up with me 😉
    #1463376
    shingen
    13941xp
    I don’t know how the machine is built inside, but I imagine you could use it as engine for texture rollers on soft materials, either self-made (sculpted, milled or 3d-printed) or even bought from GSW – in that case you may want to prepare some kind of interface between the machine and the roller.
    On a side note, if you’re looking for a machine that could be used for cutting sheets of material (plasticard, paper, plastic folders or self-printed decals – @lloyd – etc.) into intricate and repetitive shapes, I use Silhouette Cameo, a neat little cutting plotter which can be fed any vector graphics. I don’t want to pollute your topic, but in case you’re interested I can elaborate on that with some examples.
