This topic contains 6 replies, has 4 voices, and was last updated by panzerkaput 3 years, 5 months ago.
Home › Forums › Painting in Tabletop Gaming › Airbrushing Varnishes
I am on a wonderful and slow journey of airbrushing and I really only use my airbrush at the prime my figures and terrain with. But I am thinking that maybe I could varnish my figures with an airbrush, so I am asking a couple of questions here.
Firstly, is using an airbrush to varnish miniatures and terrain any good with an airbrush? I am guessing that you will then to gloss and matt varnishes as normal in a couple or so coats.
Secondly, if it is good to varnish your miniatures this way then what are the best varnishes to get?
Thirdly, do these varnished need to be thinned to be used through an airbrush? It be the same way that you want thin paint normally with thinner/flow improver or is it another way to use them?
Thanks
I’m leaving a dot here for the answers. Sadly I can’t provide any answers from experience but I’d like to learn the secrets as well.
Judging from what other people do on the youtubes I think varnish with an airbrush is a thing? maybe…
For me I am still learning and I have send the the youtube guys and each one of them is a little helpful.
Absolutely yes. Since I have an airbrush I have not spent a penny anymore on rattlecans either for priming or varnishing. The results are much better and the cost largely inferior. Plus you can varnish inside and do not have to worry about frosting anymore. You can also use varnish more often as a save point to seal the work done so far before attempting a trickier stage or for other purposes, like adding decals (after a gloss varnish) or using oil pin washes (gloss or satin varnish) and finishing everything with a matt varnish. My go to varnishes are Vallejo Polyurethane Varnishes. Consider that a 200ml bottle comes around 20ish euro and has lasted me a couple of years. I paint in average 3 to 5k miniatures per year. You can do the math…
I use Vallejo gloss varnish through my airbrush. I thin it with Vallejo’s thinner first. It’s hard to give ratios ‘cos I just judge by eye when I think it’s thinned enough. Maybe around 50/50. Couple of coats does the job. I’ve not tried any other varnishes through my airbrush so I can’t compare.
I had quite a few occasions where my airbrush would clog quickly. I found mixing the varnish and thinner outside the airbrush helped. Not sure what was getting in when I mixed in the cup. I think mixing outside the airbrush cup is generally a good habit to get into but particularly with gloss varnish.
I rinse my brush through with warm, soapy water each time I empty the cup and when I’ve finished.
I’ve not tried matt varnish through the airbrush. I’m not clear on the preparation needed to avoid frosting.
I prefer to airbrush gloss ‘cos I thought I was losing details when I brushed on gloss. I’d find small gaps in my drybrushing or edge highlighting. Airbrushing gloss is a gentler way to apply protection in my opinion.
Yes, of course you need to thin the varnish, I use both thinner and flow improver and have never had a problem with clogging. Mixing the varnish, or any other colour, outside the cup is a very good general rule: often the paint can have small bits of congealed paint that can go into the cup inadvertently and clog the airbrush. If you mix the paint or varnish outside the cup it is easy to spot and remove these.
There is no special preparation needed to avoid frosting when airbrushing matt varnish: the fact is that you apply the varnish at a much lower pressure and at the same temperature of the room you are painting in and this is all that is needed to take care of the issue.
Cheers guys for the advise
Warcradle Tease More For Next Armoured Clash Releases!
Sanguine Sin Stalks The Streets Of Venice In Carnevale
Spectre Miniatures Launch New Mythos Supplement This Week
Delve Deeper Into Warhammer Underworlds With New Warbands
Pre-Order New Slaves To Darkness For Warhammer Age Of Sigmar
Pre-Order New Edition Urban War Gamebox From Seb Games
Callisto Rides & Roars Into Bad Roll Games’ Punkapocalyptic
Wargames Atlantic’s New Plastic Peasants Are Revoltingly Good!
Separatist Call On Clanking New Droids For Star Wars: Legion
Snatch Up Corpses With Warmachines’ New Necrohavester
Fight Alongside DakkaDakka’s New Stormpride Sisters On Kickstarter
PWork Wargames Running Big New Black Friday Sale!
Loads More Burrows & Badgers Previews For New Starter Set!
Warlord Offer Sneak Peek Inside Bolt Action Armies Of Germany
They Have A Snow Troll! New Middle-earth SBG Miniature Reveals
Dive Into Bolt Actions’ 28mm Winter US Army & Airborne Collection
Slithering Creatures & Tech Savants Join Necromunda Range
FREAKZ! Mutant Murder Machines Available From Osprey Games
Cover Your Bases In Dead Animal Bits From Wargames Atlantic
New Ottomans & The French In Egypt From Perry Miniatures
Build Your Crusader-era Islamic Army With Victrix Miniatures
A New Crew Comes To Freebooter’s Fate & A Pirate Squirrel!
Buckle Some Swashes With Two New Black Scorpion Miniatures
Recruit New 15mm Desert Infantry From Slave 2 Gaming
Battle Through New Micro Art’s Pre-Coloured Japanese Terrain
Grab Digital Armoured Clash Rules From Warcradle Studios
Steamforged’s Epic Encounters Hit The Ruins Of Symbaroum!
The Fidwogs Marching Out Soon For ZombieSmith’s This Quar’s War
Crooked Dice Gives New Home To Sinbad Range For 7TV Fantasy
Spectre Miniatures Reveal Limited Remembrance Diorama
COG – Trading Bazaar
