This topic contains 9 replies, has 6 voices, and was last updated by zoidpinhead 6 years, 5 months ago.
Home › Forums › Painting in Tabletop Gaming › Airbrush blues, please help
Several months ago I got a gravity filled airbrush (Neo CN by Iwata) I used it intermittently for priming and it’s worked very well, until today. Today I was priming a batch of models black, and before I could finish them it stopped working.
I used Vallejo air black mixed with AV airbrush thinner and AV flow improver. When I started I also added a drop of AV retarder medium, but I stopped because I didn’t think it was helping the paint go further. Anyways, once I was down to the last five models (between 20-30) the airbrush stopped giving almost any pressure. I used Airbrush cleaner with flow improver and paint thinner for good measure and the stuff didn’t so much spray out as dripped out. And what spray I did get is spraying downward, as in below where the nozzle is pointing.
Please help
@brianfowler713 whats your compressor set to pressure wise?
Im assuming it was still running when the brush stopped spraying?
The spraying downwards could suggest a buildup of paint in and around the nozzle have you had that apart and cleared it out?
Could be a couple of things, mostly paint build up. Check the nozzle cap, just give it a quick once over with a cue tip dipped in airbrush cleaner. If not could be paint build up inside the nozzle where the needle presses against it.
If the airbrush itself all seems good then it could be the compressor, they don’t always like being run for too long in one go as they heat up and some internal parts can start to wear. Doesn’t seem likely though as a compressor problem wouldn’t affect the direction of the spray.
TL;DR Clean, Clean and clean again.
So the airbrush is working again and I finished priming, AND I cleaned it again. Just don’t get it because I was cleaning the airbrush. I was even cleaning it between groups of 4-5 models.
Either way, it seems fine, for now.
Are you using the Vallejo air black primer? I’ve found that after a while the chemical bond (or whatever?) of the primer breaks down and ends up being very pigment heavy no matter how much I thin it! This leads to constant pressure loss and clogging! ….or maybe that’s just me? As with most airbrush issue….. clean and clean again…..then clean some more!
The bottle just says AV Game Air, Black. Nothing about being a primer, although that is what I’ve been using it mostly for.
Airbrushes are really finnicky things, only way is to clean,clean and clean some more as you are doing.
best of luck
Honestly, I had a Neo for a while and was by far the worst airbrush I have ever known to work with – I spent more time cleaning it and stripping it down trying to get it to work than actually using it. Went back to using a Badger Patriot 105 and it’s the polar opposite – easy to maintain and works wonders
When I first started priming with my airbrush I had similar issues with using the Vallejo black paints as primers given that they clog so easily. I switched to the Stynylrez range of “easy app” surface primers. I first saw them on John’s tutorial and vlog videos here at BOW. They run well with minimal thinning through any airbrush. They are by Badger but available through various specialist suppliers in the UK. Best decision I made as they provide a really smooth surface that takes other paint well and performs excellently underneath a zenith highlight. Highly recommended.
The Shattered Lance Crashes Into Turnip28 With New Kickstarter
Blood And Bayonets Rules Announced By Firelock Games!
Get Ready To Fire English Civil War Guns From Bloody Miniatures
Guardians & Monster Hunters Coming To Marvel: Crisis Protocol
Early War Soviety Infantry Hits The Battlefield From Empress
Satyr Art Unleash Their Chainsaw Commando On Blood Devils!
Heavily Armoured Heroes Join Warhammer: The Old World Armies
PWork & Borciani e Bonazzi Release Brush Range For Wargamers
UK Games Expo 2025 Tickets Now Available To Buy!
Spellcrow Bringing New Hobgoblins To Umbra Turris Soon
Union Beta ORBAT Rules Available For New Armoured Clash Faction
Bring The Steel Chosen & Goltr Boars To Para Bellum’s Conquest
New Lore Campaign Pack Coming To Para Bellum’s Conquest
New Whisperer Miniatures Join The Drowned Earth’s Factions
Battlefront Release Battle Of The Bulge Flames Of War Armies
Westfalia Creating Stunning Red Brigade Minis For Trench Crusade
23
Héra Mini Revealed For War Of The Rohirrim & Middle-earth SBG
Unarmoured Visigoth’s Join 1898 Miniaturas’ Historical Range
Hobday & Hicks Preview Fantasy Supplement Rulebook, Warhost
Avatars Of War’s 28mm Plastic Marauders Back On Sale!
Empire Of Man Range Expands For Warhammer: The Old World
Firelock’s New Characters For Your Blood & Plunder Crews
Deep-Cut & The Army Painter Team Up On Speedpaint Pens?
Grab New Spectre Mythos Core Box & More For Lovecraft Adventures
Bad Squiddo Bring Pulp Heroines To Kickstarter This Week!
