Advise on Varnishing Minitures – Citadel?
Home Forums Painting in Tabletop Gaming Advise on Varnishing Minitures – Citadel?
This topic contains 6 replies, has 3 voices, and was last updated by  grimcrazy 6 years, 3 months ago.
  • #1253605
    grimcrazy
    1228xp
    In the past I have used Citadel Purity Seal on miniatures without any issues – but I used Administorum for the first time today and it made my metallic and blue tones quite ‘dusty’.
    Weather/temp conditions were good. Has anyone else had this experience? are there better vanishes that would enhance coulors?
    #1253609
    grimcrazy
    1228xp
    Gene 2
    #1253612
    grimcrazy
    1228xp
    I didn’t mind my cult looking a bit dusty with the varnish – but I don’t want that effect on these Eldar and Hsarlequins 🙁
    Eldar Painted
    #1253613
    grimcrazy
    1228xp
    And I spent ages blending metallic on these gang-members including colour-shifts 🙂
    Necromund
    #1253761
    mage
    20596xp
    I find the GW are ABSOLUTE RUBBISH
    Use the army painter Satin Varnish Spray and see how you get on. Test it on something first though. Avoid GW varnishes. They are the devil.
    #1253945
    12492xp
    I used to use GW rattlecan varnishes but had similar problems to those you describe more than once so I moved to the more game-durable army painter dip with a dull coat varnish over the top.  My current spray of choice for this is Testors Spray Lacquer.  It is an American product but available from specialist suppliers and some enlightened FLGS here in the UK and Europe, as well as Amazon.  Spray thin coats and respray another thin coat if the model is still too shiny.  Not perfect but the best result I had having worked through GW, Humbrol and Army Painter alternatives.  Best of luck finding your ideal finish.
    #1254100
    grimcrazy
    1228xp
    Thanks for the advise!  – I will post the results 🙂
