A solution just looking for a problem
Home Forums News, Rumours & General Discussion A solution just looking for a problem
This topic contains 7 replies, has 5 voices, and was last updated by  timchubb 5 years, 11 months ago.
  • #1353492
    So I made this: https://www.beastsofwar.com/project-entry/1353490/
    Modular, controllable, full-colour LEDs for your tabletop terrain. While the final stage is to miniaturise (that’s a word, right?) the connectors and to use super-fine wire between the LEDs, it feels a bit like I’ve created a solution to a problem nobody has asked – but could have come up with something to turn a mediocre (possibly sci-fi?) terrain piece into something amazing.
    Anyone any ideas what these could actually be put to use for?
    When I get some hobby time, I might even offer to embed some LEDs into your favourite terrain pieces – leave your ideas below…
    #1353565
    maledrakh
    11996xp
    Some random ideas
    The mothership from Close Encounters of the Third Kind springs to mind.
    That “Tech Noir” club that the Terminator first attacks Sarah Connor in.
    Anything lava or green bubbly slime, depending on which colour options are possible.
    Rivers of blood in the realm of chaos
    that ice cream van for the zombie apocalypse
    #1354170
    have done something VERY similar myself 😀 (it looks ace check my profile pic with an illuminated 4ground hut)
    On suggestion i would have is to forget about wires…. I use copper tape and conductive paint (yes you take quite a hit in resistance if its applied to thick, but you could also make a capacitive interface in the terrain it self…), the beauty of that is that you can keep the terrain gameable i.e. roofs can still come off…
    WP_20170210_19_44_45_RichWP_20170213_10_46_50_RichWP_20170213_10_57_16_Pro
    You can cut the tape with scissors, so its easy to get thin busses cut, although i use a pcb pin now on the roof to make it less critical in terms of allignment.
    My rgb rig has a different application though, i will be using it along with a miniature smoke machine i have made from an ecig and a childs bubble gun, and plan to use it for making enchanted fog and similar…
    As an enhancement to your rig, make it talk DMX then could use an opensource lighting desk app to queue effects as well, lightening and fire effects would look good…
    #1354189
    43090xp
    Spaceport landigpads
    dungeon or sewer lighting
    #1354309
    @timchubb – nice work! I’m no stranger to copper tape-based circuits (my nerdy mates at the local electronics group seem to think I do little else at the minute!) and love your modified house!
    I have tried using bare conductive paint (and even a “better/less resistive” homebrew concoction) to print circuits but found resistance to be a problem over long runs (especially when connected with microwire which, itself, adds quite a bit of resistance). Voltage drop is a real pain when trying to daisy chain LEDs! I had some moderate success by electroplating copper over the painted tracks, but that was more difficult and messy to do than using 3mm copper tape so gave it up as a bad job.
    I’m intrigued by your picture – is it a single-colour or an RGB LED? It looks like a pair of single colour LEDs; if they can, indeed, be changed (programmatically) to be any colour, please let me know – I’ve been looking for a two-wire colour-change LED for aaaagggges.
    #1354314
    @timchubb miniature smoke machine? Please elaborate – I love the sound of that!
    #1354342
    mage
    20596xp
    Man I’d burn down the house if I tried that.
    #1354345
    No that was mk1 so just some bog standard SMD white led’s im afraid, what i have done on subsequent versions (currently everything is in storage due to doing my house up) is use tape for all the conductors (but i cheat slightly and cut it using my desktop vinyl cutter) and only use conductive paint to dot the contacts on the led to the tape, as my main goal was to create a way of illuminating terrain which required zero soldering so nobody had an excuse not to 😉 basically if you can apply a decal you have more than enough ability to do this 😀
    As for the smoke machine it is litterally as simple as getting a ecig head, a fan, construct a cowling for the fan to channel air at the base of head and pulsing the fan and heating coils, 2 or 3 second bursts will produce a lot of “smoke”.  The childs bubble gun comes into play as i wanted a peristaltic pump to top up the smoke fluid (glycerol) from a larger reservoir so it could run all day, and looking at prices in farnell and rs, bubble guns came quids in as i was able to get 2 for £4 on amazon lol
    best example of a tutorial i could find is this:
    https://www.instructables.com/id/DIY-Smoke-Machine-from-Ecig-clearomiser/
    An aquarium pump could work nicely for this as well (dont currently have any spare, as i use them for my pcb fab and/or invert the bellow valves to turn them into mini vac pumps which i build SMD pickup tools from as im too cheap to buy a real one lol) but as i plan to build this into a specific bit of terrain battery powered is preferable,
